KB84954
Published: August 13, 2015
In groov Admin, cannot upgrade groov when on a link-local connection
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
Problem affects versions: R1.570.41 and lower
If you are directly connected to a groov Box using a link-local IP address (169.x.x.x), you will not be able to upgrade either groov App or groov Admin.
A link-local IP address typically occurs when the computer's Ethernet card is configured for DHCP, but it is not currently connected to a network that has a DHCP server.
To avoid this issue, you can either assign the computer's Ethernet card a fixed IP address or leave the configuration set to DHCP and connect the computer and the groov Box to a network with a DHCP server.
