KB84956
Published: August 13, 2015
Cannot access PEM file after uploading SSL certificate to groov Box
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
Problem affects: All versions
In groov Admin, after you upload an SSL certificate to the groov Box, the PEM file does not seem to be accessible. Instead, "Error - Missing Content-Type Header" appears.
