KB84983
Published: August 13, 2015
In groov Build, minor overridden tic marks disappear if gadget has non-zero minimums
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects: R3.0e and lower
Problem is fixed in version: R3.1a
If you set the minimum value for a gadget to anything other than zero and check Override Tics to enter your own tic values, the minor tic marks do not appear on the gadget.
