KB84989
Published: October 8, 2015
groov may lock up after running fine for 40 minutes (corrupt project file)
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem was discovered in version: groov App R3.0a
After running fine for 40 minutes, groov locks up and becomes unresponsive. When you restart groov and inspect the logs (click the bell icon and choose Message Logs), you see a message like this:
2015-08-10, 08:15:02 GMT-07:00 ERROR com.opto22.groov.server.database.VacuumDbHandler - Attempt to VACUUM database failed: [11] DB[5] exec() database disk image is malformed.
This issue occurs if a project file is corrupted.
Send your groov project into Opto 22 Product Support for analysis.
