KB85024
Published: September 8, 2015
GROOV-AR1 will not boot properly if Wifi adapter is removed before Wifi is disabled
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
Problem affects: groov Admin, all versions
The GROOV-AR1 groov Box can use an optional Wifi adapter, which you can remove after configuring the device and then shutting down groov.
However, groov does not properly boot up unless the Wifi has been completely disabled. If Wifi has not been disabled, the SYS LED keeps blinking and the groov Box is unresponsive.
See also:
Disable Wifi before turning off the groov Box.
