KB85033
Published: September 9, 2015
In groov Build, the first attempt to update a strategy may not work
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects: All versions
If you are using a SNAP PAC controller with groov and make a change to the PAC Control strategy, the .idb.txt file must be updated in groov so that the change is registered. However, in some browsers you may have to update the strategy twice before changes are registered.
Try a different browser.
