KB85055
Published: September 29, 2015
Memory leak may cause OptoDataLinkRuntime.exe to use more system memory
OptoDataLink
Versions affected: All
A small amount of memory leakage in OptoDataLink may cause the OptoDataLinkRuntime service (OptoDataLinkRuntime.exe) to increasingly consume more system memory over time. You may notice this issue more quickly if your OptoDataLink project contains a large number of links.
Use Windows Services (Control Panel > Administrative Tools > Services) to stop and restart OptoDataLinkRuntime.
