KB85082
Published: October 2, 2015
When you run PAC Display Runtime Pro as an administrator, it cannot connect to IO scanners
Versions affected: All versions
Note: This issue does not affect PAC Display Basic.
PAC Display Runtime Pro cannot connect to IO scanners when you run PAC Display with administrator privileges ("Run as administrator").
There are two ways you can encounter this problem:
1. Start PAC Display Runtime Pro using the Run as administrator option.
2. Start PAC Display Configurator Pro using the Run as administrator option, and then on the File menu, click Save Project and Load Runtime.
