KB85192
Published: January 19, 2016
groov events cannot reference strategy table indexes
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects: groov R3.0a and higher
Problem is fixed in version: R3.1a
If you are using groov with a SNAP PAC controller, and you select a table element from the PAC Control strategy to be used in an event notification message,  a -12 invalid table index error is generated in the controller's message queue.
When you select the tag in groov it always shows a 0, and the table appears to have only one index instead of the actual number it was configured for. This issue affects integer, float, and string tables.
