KB85201
Published: October 13, 2015
PAC Display may crash or lock up at runtime if its project has many active and enabled alarm points
Problem was discovered in version: R9.4g
At runtime, projects with many active and enabled alarm points may cause PAC Display to crash or lock up after displaying an Alarm Point Message dialog box.
Uncheck either one or both of the following settings in PAC Display > Configure > Alarming Setup:
  • Display message box for new alarm points
  • All alarms enabled at startup
Then, after the project successfully starts, you can reenable the settings.
