KB85204
Published: October 12, 2015
E1 and E2 brain boards may be corrupted if reset during startup
Versions affected: Firmware R1.1d and R1.1e
Problem is fixed in version: Firmware R1.1f and higher
If you reset an E1 or E2 brain board during startup, the brain board may become corrupted. If this occurs, the brain board could lose the following settings:
- IP address
- Optomux settings and routing information
- Custom port settings for supported protocols
Upon startup, wait at least 10 seconds before cycling power.
