KB85250
Published: October 30, 2015
E1 or E2 firmware update may fail intermittently
Problem affects versions: Firmware R1.1c, R1.1d, & R1.1f
Problem is fixed in version: Firmware R1.2a
E1 and E2 brain boards with firmware versions R1.1c, R1.1d, or R1.1.f installed may intermittently fail to update firmware. Instead, 3-4 minutes after you begin the firmware update, the brain boots back up with the previous version of firmware.
Updates fail on approximately 1 in 20 attempts.
This issue does not affect E1s and E2s with firmware R1.1e installed.
Try to update the firmware again.
