KB85296
Published: November 30, 2015
PAC Display: Start Index and Num Elements fields are editable when they shouldn't be
Versions affected: All versions
When you're configuring a tag to Send Value or Send Discrete to a numeric table, the Start Index and Num Elements fields become editable if you delete the value in the Element field (PAC Display > Graphic Dynamic Attribute > Send Value or Send Discrete > Value Tag Selection dialog box). However, you shouldn't be able to edit the Start Index and Num Elements fields because they aren't applicable to Send Value or Send Discrete attributes.
