KB85301
Published: December 10, 2015
PAC Control's Inspect window shows incorrect data for 64-bit integer tables in subroutines
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
SOFTPAC
Versions affected: Firmware R9.3e through R9.4b
Lower versions may be affected
NOTE: This is a firmware issue that affects how PAC Control's Inspect window displays data for local 64-bit integer tables in subroutines. It doesn't affect the actual data and it doesn't affect 32-bit tables, local 64-bit variables, or global 64-bit integer tables.
When you use PAC Control's Debug mode to inspect a local 64-bit integer table in a subroutine, the values in the Inspect window appear as zeroes or random data.
Do not inspect 64-bit tables in subroutines.
Opto 22 has resolved the issue.
