KB85313
Published: December 30, 2015
In groov View, Round Gauge and Range Indicator gadgets may not show complete marker values
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
All versions
R3.1a
In groov View, marker values in Round Gauge and Range Indicator gadgets may not show expected or useful decimal precision. This issue occurs when the difference between the range minimum and maximum values is small, unless the range is very close to zero (the closer to zero, the greater the decimal precision).
