KB85429
Published: April 6, 2016
XY Plot with empty title causes PAC Display Runtime to crash
Problem was discovered in version: R9.4g
If you create an XY Plot with an empty title in PAC Display Configurator, you receive no error. But when PAC Display Runtime tries to load the window that contains the plot, Runtime will shut down.
Make sure you give the XY plot a title.
