KB85491
Published: April 7, 2016
PAC Display Runtime may not display buttons and combo box controls when other graphic objects change state
Problem affects versions: R9.0a and higher
If a button or combo box is contained in another shape (for example, a rectangle or circle), and that object's dynamic attribute changes state, the button or combo box may not be displayed.
However, if you move the mouse to where the button or combo box is, it will appear again.
Hover the mouse over where the missing button or combo box should be, and it will be redrawn.
