KB85555
Published: April 7, 2016
PAC Display Runtime may fail when trying to get Historical Log File name from controller string variable
Problem affects versions: All versions
When configuring a historic log to get the filename from a controller string variable, a message in the Event Log might indicate an error and a zero-length string. If the controller variable really contains an empty string, the error is valid. But you may receive the error when the variable contains a valid string.
