KB85566
Published: June 30, 2016
OptoMMP Read requests to E1/E2 using invalid addresses return stale data
Problem affects versions: All versions
If you send an OptoMMP Read request (through PAC Manager or a custom application) to an E1 or E2 brain board, but the OptoMMP address is invalid, the NACK response will still include the requested amount of data. However, the data will be from the last successful OptoMMP transaction.
Ignore any data returned with NACK responses.
