KB85587
Published: April 7, 2016
PAC Display Configurator - PID button object appears to point to wrong PID
Problem affects versions: R9.0a and higher
Problem is fixed in version: R9.5b
In PAC Display Configurator, when you double-click a PID button, the Configuration dialog box may show a different PID than the one you configured.
The issue occurs when more than one I/O unit is configured and the PID exists on an I/O unit other than the top one in the list. The top name in the list is highlighted rather than the configured PID.
However, the PID button will work correctly for the configured PID in Runtime.
