KB85607
Published: April 7, 2016
PAC Display Configurator - Find Tags may find incorrect tag
ioDisplay Basic
ioDisplay Professional
FactoryFloor Software
Problem affects versions: PAC Display, all versions up to B9.4h, dated March 9, 2016
Problem affects versions: ioDisplay, all versions
Problem affects versions: OptoDisplay, all versions
When you search for a tag using the Find Tag dialog box in PAC Display (or ioDisplay or OptoDisplay), the results may show an object that references a different tag than the tag you are searching for.
Opto 22 has resolved this issue for PAC Display.
NOTE: No fix will be released for ioDisplay or OptoDisplay, as these are legacy software applications that are no longer being updated.
