KB85615
Published: August 18, 2016
If Legacy option isn't enabled, PAC Control may crash when importing a chart with a legacy I/O unit
PAC Control Basic
PAC Control Professional
Versions affected: R9.5a; may affect previous versions
If your PAC Control strategy isn't configured to support legacy I/O units and you try to import a chart that uses a legacy I/O unit, PAC Control may crash.
First, go to File > Strategy Options, and then select the Legacy tab. On the Legacy tab, click Enable to enable the appropriate legacy options used in the chart to be imported. Then import the chart.
