KB85673
Published: April 29, 2016
In groov, results for Modbus scalers used with array tags are incorrectly rounded
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.3a - R3.1a
Problem is fixed in version: R3.1b
In groov Build, if you use a Modbus scaler that changes an array tag's value from an integer to a floating point, the result will be incorrectly rounded to an integer.
Tags that are not arrays work correctly and are rounded appropriately. This issue happens only when using array tags.
Instead of using array tags, address the array location directly as a single tag.
