KB85706
Published: August 19, 2016
.NET OptoMMP SDK: Characters missing from Point Name
.NET OptoMMP Software Development Kit for SNAP PAC
Problem affects version: 3.0.5.0
Problem is fixed in version: 3.0.6.0
When you use the ReadAnalogPointConfiguration4096 function, the first four characters of the Point Name string are cut off. For example, if the point name is "DG2A_501" the function will return "_501".
