KB85713
Published: April 29, 2016
groov dynamic tag array not operational
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects version: R3.1a
Problem is fixed in version: R3.1b
In groov Build, when you add a dynamic tag array, you may see one of two symptoms:
- The dynamic tag array can be configured but will not be operational.
- If you already have one dynamic tag array that works, it will lose its configuration when you add another dynamic tag array, and neither will work.
You may see an error message in groov that says: "The gadget's tag is a different data type than what the server or device provided."
