KB85723
Published: April 6, 2016
On a SNAP high-density digital (HDD) output module, a point that was turned off is on, or vice versa
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
Problem affects versions: Firmware R7.1a - R9.4c
Problem is fixed in version: Firmware R9.5a
If more than one PAC Control flowchart running on a SNAP PAC rack-mounted controller writes to the same high-density digital output module on its own rack, the changes made by one chart may be overwritten by the other, even if they're not accessing the same points.
For example, a SNAP-PAC-R1 controller writes to an HDD output in position 2 on its local rack:
  • If Chart A turns on points 1 through 12,
  • And then Chart B turns point 22 either off or on,
  • One or more of points 1 through 12 may remain off.
Use one flowchart to make all changes to an HDD module on the controller's rack.
