KB85736
Published: July 10, 2017
groov erratically displays yellow triangle with exclamation point (communication timeout)
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN-BASE
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
OPTOEMU-SNR-3V
OPTOEMU-SNR-DR1
OPTOEMU-SNR-DR2
Versions affected: All versions of PAC firmware through R9.5d
Problem is fixed in version: FW R9.5e
Note: This is a controller firmware issue. Due to the specific method it uses to scan data from the controller, groov appears to be the only product that exhibits this issue.
When a TCP/IP session is disconnected from the host task of a controller (default port 22001) while groov is communicating with a controller, groov may briefly display the yellow triangle with exclamation point icon, indicating a communication timeout.
Any of the following actions can expose the issue, because they connect to a controller’s host port at TCP:22001 by default:
- Exiting from PAC Control’s debug mode.
- Closing a PAC Terminal Status or Terminal Window.
- Terminating an OptoOPCServer connection to the controller.
- Terminating a PAC Display HMI instance connected to the controller.
- Terminating a communication session with the PAC-DEV-CONTROLLER-DOTNET SDK.
