KB85737
Published: April 29, 2016
In groov Build, a configured Event condition displays incorrect boolean settings
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects version: R3.1a
Problem is fixed in version: R3.1b
When you create an Event in groov Build, a true/false condition displays the setting as equal to true even though the event condition is set to equal false.
The event operates as it should, even though the display shows the incorrect setting.
