KB85793
Published: April 27, 2016
PAC Display Professional project loads slowly, may show out of memory error; project .UUI file grows to several hundred megabytes
Problem was discovered in version: R9.4g and may affect previous versions
The PAC Display project file (file extension .UUI) grows to several hundred megabytes over the course of saving the project. The large file size can cause the project to load very slowly. In addition, you may see a PAC Display popup message showing "Out of memory" or "PAC Project Load Status (Not Responding)."
This issue affects PAC Display Configurator Pro only (not PAC Display Basic).
If this problem affects you, download and install version R9.5a (or higher), open the affected project, and save it. File size should return to normal.
