KB85795
Published: July 10, 2017
Host Task stops processing commands if you stop strategy while in Debug mode
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
SOFTPAC
Problem was discovered in version: PAC firmware R9.4c (Lower versions may be affected)
Also affects: PAC firmware R9.5d
Problem is fixed in version: FW R9.5e
While using PAC Control in Debug mode, if a chart has one or more breakpoints and you click the Stop Strategy button, the SNAP PAC controller’s host task may unexpectedly stop processing commands, resulting in a loss of communication with the controller.
Remove all breakpoints before clicking Stop Strategy.
If you've already clicked Stop Strategy, you can either:
- Cycle power to the controller, or
- Send the "Restart from powerup" command via PAC Manager
