KB85813
Published: May 4, 2016
groov Event Notification email not saved if only tag(s) are added
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.0a - R3.1a
Problem is fixed in version: R3.1b
If you create an event in groov Build and in the email notification editor add one or more tags but no text, when you click Update Event the event is not saved. Or when you click Return, you are not prompted to save changes.
Add some text to the notification email, and then you can save it.
