KB85815
Published: October 28, 2016
REST API: Writing a NaN to an analog output or float writes 0 instead
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
Versions affected: PAC firmware R9.5a through R9.5c
Problem is fixed in version: PAC firmware R9.5d
When using the REST API to write a NaN ("not a number") value to an analog output point or to a float variable, the NaN is stored incorrectly as a 0 (zero).
Note that this issue does not affect reading NaN values; GET requests correctly return NaNs.
