KB85816
Published: May 26, 2016
In groov, writing to an OPC UA array index gives an "unexpected error"
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.0a and higher
In groov, when you try to write to an OPC UA array index, a warning comes up that says "The value could not be written. An unexpected error has occurred."
