KB85817
Published: June 30, 2016
In groov, OPC UA byte array shows data type error
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.0a to present
Problem is fixed in version: R3.2a
If you're using an OPC UA server and trying to connect to a byte array, an error appears saying that the expected type does not match the actual type.
