KB85823
Published: July 31, 2017
RESTful API: Out-of-range float values appear as 0 or "inf" instead of returning an error
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
Versions affected: PAC firmware R9.5a through R9.5d
Problem is fixed in version: FW R9.5e
When using the RESTful API to send float values to a variable, the value will appear in PAC Control and in the REST interface as:
  • 0 (zero) if the value sent is too small
    For example: {"value":1.2345678E-39}
  • inf if the value sent is too large
    For example: {"value":1.2345678E39}
In both cases, the controller should return a -13 (Overflow error) without changing the value of the target variable.
Validate values before using them with the RESTful API.
