KB85826
Published: July 31, 2017
RESTful API returns an analog point's value even though the wrong request is sent
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
Versions affected: PAC firmware R9.5a through R9.5d
Problem is fixed in version: FW R9.5e
If you mistakenly use the .../device/strategy/ios/analogInputs/{ioName}/eu request* to get an analog output's value in Engineering Units (EU), the controller will respond with an OK status and the value of the requested output.
The controller will respond similarly if you mistakenly use the .../device/strategy/ios/analogOutputs/{ioName}/eu endpoint to get an analog input's value in EU.
In both cases, the controller should respond with a 404 (Not found) status and either a -28 (Object not found) or a -29 (Wrong object type) error message.
*A request is a URL that follows the syntax for the SNAP PAC REST API.  It's also known as an "endpoint."
