KB85832
Published: June 30, 2016
In groov, changing text in a copied Text Gadget may affect the original one, and vice versa
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.1a and higher
Problem is fixed in version: R3.2a
If you copy a Text Area gadget, paste it on a different page, and change its text, the text in the original gadget may also change.
Instead of copying Text Area gadgets, use new ones only.
