KB85839
Published: May 4, 2016
OPC UA dynamic array shows incorrect index range in groov event notification email editor
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.0a - R3.1a
Problem is fixed in version: R3.1b
In groov Build, when you configure an OPC UA dynamic array in an event notification email, you receive an error that the array index range must be between zero and a negative number.
