KB85897
Published: May 26, 2016
PAC Display Runtime writes to Runtime Operator Log when logging is not enabled
Problem affects versions: All versions
If you log in or log out as a global operator, PAC Display will attempt to write to the Runtime Operator Log file even if Runtime Operator Logging is not enabled. You will see a message in the event log about writing to a file RDXXXX, where XXXX is the month and day.
