KB85910
Published: July 28, 2016
groov Trend gadget minimum update intervals not enforced
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.1a and higher
Problem is fixed in version: R3.2a
In the Trend properties panel, if you set an update interval less than the minimum allowed value (1 second), you are not stopped or warned.
Switching away from the properties panel and back to it resets the value you chose to the minimum, but you're not notified.
