KB85911
Published: July 28, 2016
groov Trend gadget properties panel does not convert units in the Period and Update Interval fields
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.1a and higher
Problem is fixed in version: R3.2a
In the Trend gadget properties panel, changing the Period or Update Interval units (for example, changing from minutes to hours for the Period) does not update the value for that field appropriately. For example, if you had a trend with a Period of 2 hours, changing the units to minutes should update the value field to 120.
