KB85914
Published: May 25, 2016
Modbus/TCP function Report Slave ID (0x11) does not return any data
SNAP-PAC-S1-FM
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
SNAP-PAC-EB1
SNAP-PAC-EB1-FM
SNAP-PAC-EB1-W
SNAP-PAC-EB2
SNAP-PAC-EB2-FM
SNAP-PAC-EB2-W
G4D32EB2
Problem affects versions: Firmware R9.4c and lower
Problem is fixed in version: Firmware R9.5a
When you send a Modbus/TCP Query to determine the Slave ID (function 0x11), a Modbus/TCP response with a length of 0 is returned, instead of the expected response with length 16 and the data listed in form 1678, the Modbus/TCP Protocol Guide.
Use the OptoMMP protocol to find out the same information.
