KB85968
Published: August 22, 2016
E1/E2: Powerup Clear Expected Error always transmitted as a Write Response
E1
E2
Problem affects versions: R1.2a and lower
Problem is fixed in version: Firmware R1.2b
After an E1 or E2 brain board is restarted, a "Powerup Clear Expected" (or PUC Expected) error is sent to the host. Normally when the host receives this error, it sends a PUC command to the brain to clear the Powerup flag in the brain.
With this issue, the PUC Expected error is always returned in a Write Response packet (tcode=2), no matter what command was sent. The host may be unable to match the response with the command it sent.
This issue affects the use of an E1 or E2 with OptoOPCServer as well as custom applications.
