KB85999
Published: August 19, 2016
When restoring a project in groov Build, typing in the Project Backup field produces an error
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: All versions before R3.3a
Problem is fixed in version: R3.3a
When you're trying to restore a project in groov Build (File > Restore Project from Computer), if you type a path and filename into the Project Backup field, an error occurs that says the filename is invalid.
Although this field currently allows typing, it was designed to show the path after you have browsed to it.
Instead of typing in the field, click the Browse button and locate the file.
