KB86024
Published: September 23, 2022
Revision: 4.0
PAC Control should report a compile error if the index to a string table reference is missing in an OptoScript block
PAC Control Basic
PAC Control Professional
When referencing a string table in an OptoScript block, PAC Control erroneously lets you omit the table's index. This issue may cause unpredictable behavior when you download and run the strategy.
Make sure that you add the bracketed index when you use a string table element in a script command.
