KB86038
Published: August 1, 2017
RESTful API stops working if the control engine's default host port is turned off or is changed from 22001
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
Versions affected: PAC firmware R9.5a through R9.5d
Problem is fixed in version: FW R9.5e
The RESTful API interface stops working if you turn off the control engine's default host port or change the Host port to use a port number other than 22001.
This issue happens even if the Control Engine's host port is changed to 0 to turn off the default host port.
