KB86044
Published: October 9, 2023
Configuring and reading SNAP-AILC and SNAP-AILC-2 modules in PAC Control
PAC Control Basic
PAC Control Professional
R6.1c to current
NOTE: This KB article is for informational purposes. This issue is not a defect in PAC Control.
Use Channel 1 of the SNAP-AILC or SNAP-AILC-2 modules when using the following configuration commands:
  • Set Analog Load Cell Fast Settle Level
  • Set Analog Load Cell Filter Weight
When reading values from the module, use the following channels:
  • Channel 1 = raw/unfiltered value
  • Channel 2 = filtered value
For more information, review these commands in the PAC Control Command Reference (1701).
