KB86046
Published: August 1, 2017
The RESTful API may return an error code in response to a valid request
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
Versions affected: PAC firmware R9.5a through R9.5d
Problem is fixed in version: FW R9.5e
Sometime the SNAP PAC RESTful API returns an error code (for example, -5, -39, -58, or other negative number) even though the request* is valid.
*A request is a URL that follows the syntax for the SNAP PAC REST API. It's also known as an "endpoint."
