KB86047
Published: August 1, 2017
SNAP PAC RESTful API: Invalid request returns unexpected results and doesn't give an error code
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
Versions affected: PAC firmware R9.5a through R9.5d
Problem is fixed in version: FW R9.5e
If a request's* syntax is not quite right, you may receive unexpected results, but no error code.
For example, this request:
/api/v1/device/strategy/tables/floats/TableFloat?elementnum=1
appears to request just one element, but returns all elements instead.
The problem is that elementnum should have been numElements. Instead of a list of all elements, a -36 error should have been returned.
*A request is a URL that follows the syntax for the SNAP PAC REST API.  It's also known as an "endpoint."
