KB86071
Published: October 28, 2016
REST API does not return -Infinity values as strings
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
Versions affected: PAC firmware R9.5a through R9.5c
Problem is fixed in version: PAC firmware R9.5d
When a tag's value is -Infinity (negative infinity), the REST API returns this value as:
-inf
For example:
{"name":"fAlwaysNegINF","value":-inf}
Because the value is not surrounded by quotation marks (which is the correct way to denote a value in JSON), this issue can cause problem when you try to parse the returned JSON string.
In PAC firmware R9.5d:
  • -Infinity values will be returned as "-Infinity"
  • Infinity values will be returned as "Infinity"
    (In firmware R9.5a through R9.5c, Infinity values are returned as "inf")
